description
interface-config-radio-instance
Configures the selected radio‘s description that helps differentiate it from other radios with similar configurations
Syntax
description <WORD>
Parameters
description <WORD>
description <WORD> Provide a description for the selected radio (should not exceed 64 characters in length).
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#description "Primary
radio to use"
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context
 interface radio1
  description "Primary radio to use"
  channel 1
  data-rates b-only
  beacon period 50
  beacon dtim-period bss 1 5
  beacon dtim-period bss 2 2
  beacon dtim-period bss 3 5
  beacon dtim-period bss 4 5
  beacon dtim-period bss 5 5
  beacon dtim-period bss 6 5
  beacon dtim-period bss 7 5
  beacon dtim-period bss 8 5
  beacon dtim-period bss 9 5
  beacon dtim-period bss 10 5
  beacon dtim-period bss 11 5
  beacon dtim-period bss 12 5
  beacon dtim-period bss 13 5
  beacon dtim-period bss 14 5
  beacon dtim-period bss 15 5
  beacon dtim-period bss 16 5
  antenna-gain 12.0
  aggregation ampdu tx-only
--More--
Related Commands
no (radio-interface-config-command) Removes a radio‘s description
